Shopsmith Jointer Knives
Replacement Jointer Knives Keep Your Jointer Cutting at its Best
Set of 3 Replacement Jointer Knives — 505640
Having a spare set of jointer knives could keep you working in the event of a nick or other knife problem
Set of three hardened steel knives, precision match-ground to Shopsmith’s exacting requirements.
Our rigid quality control standards ensure that every knife blade will be exactly the same size, with the same precision edge bevel to guarantee accurate cuts, even if used in conjunction with old blades! Once the blades are ground and honed to produce a keen cutting edge, they are treated with a special rust preventative solution for lasting serviceability.
We recommend that you have a spare set of knives on-hand at all times, in the event of accidental nicking. This way, down time will be kept to an absolute minimum, and you’ll be able to continue working on your project with minimal interruption.
Includes: Set of 3 jointer knives
Product Reviews
Watch this Video On Setting Jointer Knives!
Video Icon
Shopsmith Tools In Action
Jig For Setting Jointer Knives
