Find Your Part
- Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
- Click/touch and drag on the diagram to find your part.
- Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # | Part # | Description |
0m | Main Assmbly | |
0z | 502955 | (incl 1,2) |
1 | N/A | Tracking Screw |
2 | N/A | Rollpin, 5/32 x 11/16 |
3 | 502958 | Belt Sander Stop Nut |
4 | 502957 | Belt Sander Tracking Knob |
5 | 515813 | Plug Cap |
6 | 502960 | Belt Sander Tie Bolt |
7 | 502959 | Belt Sander Table Spacer Tube |
8 | 120382 | Washer |
9 | 120377 | Hex Nut |
10 | 222460 | Set Screw |
11 | 503024 | Belt Sander Tinnerman Clip |
12 | 5030049 | Belt Sander Auxillery Shaft Cap |
12z | 513061 | (incl 13-15) |
13 | N/A | Table Tilt Lock |
14 | N/A | Retaining Ring |
15 | N/A | Locknut |
16 | 502999 | Belt Sander Table Tilt Indicator |
17 | 502998 | Belt Sander Indicator Washer |
18 | N/A | Self Tapping Screw #8-32x1/4 |
19b | 124818 | Hex Jam Nut |
19 | 51485402 | Belt Sander Dust Chute |
19a | 514521 | Dust Collector Elbow Attachment |
20 | 502698 | Belt Sander Hex Stop Nut |
21 | 502988 | Belt Sander Nut Cup |
22z | 503402 | (incl 23-25) |
22 | 120388 | Flat Washer |
23 | N/A | Base Casting |
24 | N/A | Drive Stud |
25z | 515565 | Inner Frame Assembly (incl. 26-28) |
25 | N/A | Trunnion Guide |
26 | N/A | Rollpin, 1/4 x 5/8 |
27 | N/A | Trunnion |
28 | N/A | Right Frame Side |
30 | 5029639 | Belt Sander Back-Up Plate |
31 | 514050 | Belt Sander Platen Mounting Flat Head Screw |
32 | 51553801 | Belt Sander Outer Frame |
33 | 445446 | Tinnerman Clip |
34 | 502985 | Belt Sander Trunnion Washer |
35 | 502974 | Belt Sander Trunnion Stud |
36 | 502989 | Belt Sander Trunnion Lock Nut |
36m | Idler Drum | |
36z | 502934 | (incl 37-47) |
37 | 513732 | Roll Pin |
38 | 502945 | |
39 | N/A | Tension Cam |
40 | N/A | Bearing |
41 | N/A | Idler Drum |
42 | N/A | Spring Plug |
43 | 504553 | Flat Washer |
43a | 515619 | Belt Sander Idler Drum Spring Washer |
44 | 502937 | Belt Sander Thrust Washer |
45 | N/A | Idler Shaft |
46 | N/A | Torsion Spring |
47 | N/A | Rollpin |
47z | 502874 | (incl 48-54) |
47m | Tension Knob | |
48 | N/A | Retaining Ring |
49 | N/A | Lock Washer |
50 | N/A | Latch Spring |
51 | N/A | Tension Knob |
52 | N/A | Drive Screw |
53 | N/A | Washer 1/8 |
54 | N/A | Knob Latch |
55 | 501027 | Belt Sander Retaining Ring |
56m | Drive Drum | |
56 | 502923 | Jointer & Belt Sander Medallion |
56z | 502789 | (incl 57-62) |
57 | N/A | Ball Bearing |
58 | N/A | Bushing |
59 | N/A | Drive Drum |
60 | N/A | Rollpin |
61 | N/A | Drive Shaft |
62 | 502932 | Drive Sleeve |
63 | 502961 | Belt Sander Finger Spring Washer |
64 | 513191 | Socket Head Screw |
64m | Table | |
64z | 503406 | (incl 65-71) |
65 | N/A | Rollpin, 1/4 x 7/8 |
66 | 120388 | Flat Washer |
67a | 502318 | Special Washer |
67 | 518307 | Belt Sander Table Tilt Lock Bolt |
68 | N/A | Table |
69 | 502992 | Belt Sander Table Support Spacer |
70 | N/A | Tilt Slide |
71 | N/A | Drive Stud |
71z | 503407 | (incl 72,73) |
72 | N/A | Mounting Rod |
73 | N/A | Table Support |
73z | Miscellaneous | |
74 | 5137779 | Bandsaw & Belt Sander 6" Long Eccentric Post |
75 | 115321 | Set Screw |
76 | 120377 | Hex Nut |
77 | 120394 | Flat Washer |
78 | 122181 | Hex Bolt |
79 | 5035769 | |
80 | 222458 | Allen Set Screw |
81 | 51368601 |
diagram https://www.shopsmith.com/service/beltsander/blt_diagram.htm
https://www.shopsmith.com/service/beltsander/index.htm
