Find Your Part
- Use the zoom tool, mouse wheel, or pinch to zoom on the diagram.
- Click/touch and drag on the diagram to find your part.
- Click/tap on the reference number in the diagram, or enter it here to filter the parts list table below.
Show Part
Need Help?
Call Shopsmith U.S. Based Customer Care — 937-890-5197Monday - Friday 8:30 am to 4:30 pm Eastern Time.
Email Customer Care — customerservice@shopsmith.com
Parts List:
Ref # | Part # | Description |
0m | 513618 | (incl 1-19, 21-23) |
0z | 504144 | (incl 1-5) |
1 | 518379 | MARK V 520/510/505 Single Tilt Base |
2 | 504293 | Base Arm Vertical Lock Knob |
3 | 504146 | Bench Tube Locking Bar |
4 | 120382 | Washer |
5z | 504148 | (incl 6-18) |
5 | 138245 | Hex Bolt |
6 | 504158 | Headrest Lock Shaft |
8 | 504161 | Headrest Lock Spring |
9 | 504153 | Hex Socket Set Screw |
9z | 501286 | (incl 10-12 or 21-23) |
10 | na | Left-Hand Stud |
11 | na | Sleeve and Insert |
12 | na | Right-Hand Stud |
13 | 517768 | |
14 | 504157 | Headrest Cam Pin |
15 | 5041569 | |
16 | 504146 | Bench Tube Locking Bar |
17 | 120382 | Washer |
18 | 138245 | Hex Bolt |
19 | 504163 | Bench Tube |
20 | 501193 | Way Tube |
21 | na | Right-Hand Stud |
22 | na | Sleeve and Insert Assembly |
23 | na | Left-Hand Stud |
24 | 518381 | MARK V 520/510/505 Single Tilt Base Arm |
25 | 50426401 | (incl 26) |
26 | 502051 | Set Screw |
27 | 502051 | Set Screw |
28 | 517642 | External Retaining Ring |
29 | 522816 | MARK 7 / MARK V 520/510/505 Base Arm Pin |
30z | 522064 | |
30m | 522063 | (incl 31-33) |
30 | 50416201 | MARK 7 / MARK V 520/510/505 Leg |
31 | 518114 | Leg Mounting Truss Head Screw |
32 | 115546 | Lock Washer |
33 | 120372 |
